  1. Stevebrooks
    Stevebrooks Newbie
    Hi (Again).
    Is there an easy way or replacing my steering wheel?
    The one on the car is not an original Trabi one and I have bought a replacement from Reich Tuning along with a couple of pins. I guess I have to remove the cowling and knock the existing pin out (with something? Hammer and screwdriver??) then fit the new one and bash a new pin in ?
    Cheers
    Steve
  2. DaveinOz
    DaveinOz Aussie Trabant Nutter Forum Donor
    Hi Steve, I replaced mine recently, the pin was seriously stuck in there. I ended up using a balljoint separator to push it out because a gentle tap with a hammer and punch was not doing anything and I was worried about using too much force by hammering on the steering column. I would recommend using a puller or some sort of other tool to ease the pin out. After that I used a g-clamp to fasten the pin back in to the new steering wheel.
    scarrabri likes this.
    I had no luck using the hammer and punch method. I ended up using a C-Clamp, a bolt the same diameter of the pin and socket larger than the pin. Then just started cranking the C-clamp down until the pin was pushed inside the socket.
    Getting the pin back it, I just started it in with a hammer then used the C-clamp to push it back in.
  4. barrie
    barrie Puttering Along
    balljoint separator only way good advice daveinOz [​IMG]
  5. ummeli
    ummeli Premium Member Forum Donor
    I also replaced an original steering wheel with a better one from Danzer Autoteile. It was just a hammer and pin job.
    For some reason I can't make contact with Reich Tuning, but I don't think they ship to the U.S. anyway.
    Do feel to bad. They have no drop down box for United States. I emailed the guy (twice) to see if he would sign me up fro an account but never heard back from him. I guess he didn't want to do business outside the E.U.
  7. kev the builder
    I hope they do or us in the uk may find ourselves unable to order parts soon!
  8. barrie
    i have had a look on rich tuning found this
    "For shipping abroad, higher shipping fees apply. The valid for the respective country package is displayed when ordering after entering the appropriate delivery address, or - if you are logged in your customer account with a stored address - already in the shopping cart."
