1. barrie
    barrie Puttering Along
    hi all It has taken me about a year but old girl is now running so its time to get started on the brake system so far i have the car on jack stands took of the wheel's brake drum's and now need to remove the hub's i have undune a 36mm nut and the bent metal washer to find the hub's solid so i put a 3 arm gear puller around it and broke my puller. i have been today to buy a hub puller that fits on 2 of the wheel bolts
    should i use lube,heat or a hammer?
    Non the hubs can be tight you need the correct trabi hub puller,hammering them can easily damage them
  3. barrie
    what dose a trabant hub puller look like? and where can I get 1 from?
  4. Steve
  5. barrie
    is this the tool?
  6. Steve
  7. tricken
    tricken Loyal Comrade
  8. barrie
    when doing the brakes on old p50 you need this brake piston on the back [​IMG]
