1. Ostapack
    Ostapack Newbie
    Moin folks,
    Got the ignition up and running and cleaning the Mikuni carb as the Trab still isn't starting. Looks like I am missing the above part, maybe from a previous cleaning or adjusting. It seems like it would be important and necessary. Can any Mikuni owners let me know if this part should be there?
    The car used to run, and I find it hard to believe that I lost this or that it came loose..
    I appreciate the help!
  2. Ostapack
    Ostapack Newbie
    Well it is running now, barely if hardly idling, but we have to use starter fluid to start. Ideas? Bad vacuum? Missing air adjuster screw?
  3. A Spooky Ghost
    Hi, did you time both cylinders? Are your condensers good. If there is a air leak, it could come from : The carb flange, cylinder base gasket, crank seals, case halves, head gasket. Thats about it....
