1. Zausel
    Zausel Genosse Forum Donor
    After I messed up my timing and then reset it, the car is very sluggish going into the next gear. I know bad timing messes up a carb but why this? I reset it back and after finding a bit of a leak at one head gasket and fixing that, it sounds better than ever.
    I didn't change anything on the carb except a bit if fiddling with the needle valve (mix ratios) and I put that back to where it needed to be.
    I'd rather not pull the carb and take it apart.
    Just don't know why it's sluggish all of a sudden.
  2. Andrewwoey
    Bad timing will not mess up the carb. It as no contact with the carb. You can adjust the carb to try and compensate for bad timing, but it will just feel under powered.
  3. Zausel
    So I am at a loss as to why it went South all of a sudden. The WHIMS says to always make sure timing is set correctly before giving the carb a tuning.
    I'll see if this one is plugged somewhere down the line.
  4. Wartburg353W
    Did you do anything to the advance mechanism when you were doing the timing?
  5. Zausel
    It's EBZA. 3mm BTDC measured with a depth gauge and a test light between both terminals of the appropriate coil, and the plates were adjusted until the light turned off.
  6. Andrewwoey
    If it ran well before you done any timing adjustments, then its most likely your issue will lie there.
  7. Zausel
    Yup. My thoughts exactly
  8. Zausel
    I'm just confused as to why the timing, set to specs, is causing issues. I'll just keep messing with it.
  9. Andrewwoey
    What was it's settings before, when it ran ok? Have you disconnected any thing on the ignition system and put back incorrectly?
  10. Zausel
    Well, when I hit it with a timing light, the marks were a few degrees above the crankcase seam. Then I used the light to bring the markings down to the seam. Then it ran poorly. Set the cylinders to 3mm BTDC and it idles fine.
    Going to check the main jet on the carb after the weekend. Maybe something is blocking or there is gunk in the bowl.
  11. Andrewwoey
    A carb service is never a bad thing, especially on a very old vehicle.
  12. A Spooky Ghost
    I'm sure you already checked this -but, the magnetic spinning rotor attached to the crank shaft. Try to gently wiggle it with your hand.
    It should be tight with the crank, and have no play. Mine backed off, and made the car sound, and run funny.
    Also, it is hard telling about the "factory" timing marks. Chances are your engine has been apart one time, and had a another crank in it.
    Maybe check your plug wires- for shorting to ground while running.
  13. Zausel
    Rebuilt the carb about three years ago but it sits a lot and I just replaced the petcock with a solenoid, maybe I knocked something loose and it's plugged.
  14. Zausel
    Think I got it...I just installed an after market fuel solenoid... The flow is horrible. No where near the 250ml/minute you should get out of the float valve....
  15. Zausel
    Petcock is back and so is Zausel. I got some advice from a Trabi-Freak once; don't change anything on that car.
    It's all a delicate balance.
  16. Andrewwoey
    Brilliant. I'm glad the problem as been sorted. Now time for you to get some miles on the car.
  17. RogerDerSchrauber
    The main thing I find to keep the Trabant working OK is to follow the maintenance schedule as prescribed in the owner‘s manual. That, and to drive it regularly. Trabis don’t like standing around. Even in the winter I take it out for a spin occasionally, when it’s dry outside. So far, so good.
    Caleb likes this.
  18. Zausel
    The more I drive it, the better the carb seems to be.
  19. Caleb
    Caleb Loyal Comrade
    Regular use really does make a difference. When I first got my Trabi it had been sitting for a while and would choke out in higher gears and die. Wait a few minutes and it would start back up and take off. The more we drove it the better it got. Just clears out the cobwebs and gets everything working the way it should. Can be really frustrating though when its not working right.
  20. Zausel
    Well, when replacing the EBZA with the MBZA I found one of the control wires leading into the distributor had severed and I was running on one cylinder....
