1. barrie
    barrie Puttering Along
    go under the gear box and undo the 19mm drain plug and collect waste oil in a pan when all oil is out put back drain plug and tighten
    as you stand looking at trabant go to the right side of the gear box and undo and remove oil level plug 13mm then go on top of the gear box undo the top fill plug 19mm then add ISO VG 68 Hydraulic Fluid until it comes out side of gear box its about 1ltr then replace 13mm and 19mm plugs then you are all ready
