1. Rezzato
    Rezzato Puttering Along
    I found this 1980 601 in the Los Angeles area. The owner is asking around $3500 and it is not registered in the State. Says the battery needs to be charged and it is good to go, lot's of recent maintenance. Do you think I should go for it? I would have to sell my 1986 535I in order to afford this Trabant. Trabi 4.jpg trabi3.jpg trabi5.jpg Trabi.jpg Trabi2.jpg trabi 6.jpg 14731231_10210988439010575_4394047284134218367_n.jpg
  2. RogerDerSchrauber
    I wonder if that is the one that used to have the Calif.plate ZWICKAU on it? Or maybe DDR-CAR? Ask the seller. I think he used to be on this forum.
  3. Rezzato
    He said he brought it in around 2011 and was not able to register it so it has been sitting.
  4. RogerDerSchrauber
    Can't be any kind of legal reason, since 1) it had to have a clear title to be imported into the States, unless it was done illegally... 2) if it has brakes, seat belts, lights, horn, etc. it should pass motor vehicle inspection and 3) mine got registered, insured and inspected in Massachusetts, which is even stricter than California.
  5. mbeamish
    There is an aluminium plate on firewall with chassis number and year of manufacture . The important bit though is the actual chassis number which is on a steel tag welded behind the fuel tank. Check they are both there ( and read the same) and match the title or foreign logbook
    Also trabis don't like sitting unused . Get it started and see if brakes pull to one side. If they do you will probably have to fit all new wheel cylinders ( easy enough but a bargaining point)
  7. JASONCHAD
    If you could get it registered it is probably a pretty fair deal, But if it were me, I would probably start negotiating at $2500, and be happy to get it around $3000
    Rezzato likes this.
  8. Rezzato
    Guys, I know what to check for lol. There is a problem in California with CARB. It is what held me up on my 89 Trabi.
  9. Rezzato
    Got it! Has a fuel delivery problem. Will start cleaning and repairing everything when it stops raining. 15145145_10211253794284291_52229916_o.jpg
    BillB and RogerDerSchrauber like this.
  10. mbeamish
    I thought the sun always shone in California :) Good luck with your new project
    Rezzato likes this.
  11. RogerDerSchrauber
    Awesome! Enjoy the Trabi! It is a car like no other.
    Rezzato likes this.
  12. Rezzato
    I enjoyed my first one all right... 12398274_10208214093413669_1368997265_o.jpg
  13. Ron
    Wow, what happened there?
  14. Ron
    Ok , I just found your thread... so bad! I hope you find another one ok.
    Rezzato likes this.
  15. BillB
    BillB Loyal Comrade Administrator Forum Donor
    Congrats on your new ride!
    Rezzato likes this.
  16. Rezzato
    Polishing up nicely.
    Fixed the fuel problem but it still runs like it only has 5hp. Will check plugs and swap carburetor. If not that then I will pull the heads and exhaust manifold.
    15183832_10211300549773149_2101239452_o.jpg 15233837_10211300940382914_1899834238_o.jpg
    BillB and Keri like this.
  17. Keri
    Low power? make sure both cylinders are running! A dead cylinder will have a cool spark plug and cylinder head after you shut it off, the running cylinder will be hot or at least warm.
    Rezzato likes this.
  18. BillB
    Cleaning up great!
  19. Rezzato
    Keri, you are right, it's only hot on the passenger side. I will check plugs to start.
  20. Rezzato
    Found some new plugs in the trunk, tried them and it runs great.
