Clutch replacement
trondd Avatar
trondd trondd
I just took the heads off, yeah. Did them one at a time to keep from throwing carbon from one side down the hole on the other side.
I think the clutch is still slipping. sad smiley
A Spooky Ghost Avatar
A Spooky Ghost A Spooky Ghost
USA   USA
Check the pedal has some free play in it. Mine started slipping after giving many rides at the Nov. Trabi meet. Adjusted it a lil loose, got some more life out of it...
RogerDerSchrauber Avatar
RogerDerSchrauber Roger Fuller
Northborough, MA, USA   USA
push the pedal down with your hand. Should be like half an inch max that it goes down before you feel resistance.
trondd Avatar
trondd trondd
It may have been too tight. I loosened it up but haven't gone for another drive.
trondd Avatar
trondd trondd
Got out for a spin during lunch. Still seems to be slipping. Makes some noise with the clutch in, too. I don't like it. sad smiley
I had to file down the pressure plate to fit the flywheel. I wonder if it's not seated straight. I also broke a bolt over tightening it (put one of the old ones back in) maybe others were broken and I didn't know... Or the flywheel needed to be replaced or resurface (looked ok) and it's slipping there.
Ugh... It's getting too hot for this. grinning smiley
USA   USA
Maybe the carbon throwout bearing is loose, or cocked? Might also be the pressure pate springs are weak, and or cracked.
trondd Avatar
trondd trondd
Ok the noises were my license plate bracket vibrating against the bumper.
Accelerating up hill, especially in 4th really feels/sounds like it's slipping but now I don't know if I'm imagining it. Maybe I'm fighting the freewheel.
I guess I wait and see what breaks, if anything.
about 2 months and 1 week later...
Keri Avatar
Keri Keri R.
Chicago! Run 4 your life!, IL, USA   USA
In reply to a post by trondd, post: 68220, member: 4047 Ok the noises were my license plate bracket vibrating against the bumper.
It is probably best to not accelerate up hills while in 4th gear, as this puts much stress on the freewheel and also the engine crankshaft... Why not downshift to 3rd instead?
trondd Avatar
trondd trondd
Because it was screaming in 3rd gear. So, I was either going fast enough for 4th or the clutch was slipping...
Anyway...point noted.
Keri Avatar
Keri Keri R.
In reply to a post by trondd, post: 68279, member: 4047 Because it was screaming in 3rd gear. So, I was either going fast enough for 4th or the clutch was slipping...
If it only slips in 4th gear it could be a slipping freewheel. Hopefully not.
1984 Trabant 601
