moor unexpected stops at the side of the road
trondd Avatar
trondd trondd
Yes. The little one on the right here:
There should also be the long one inside the fuel tank but it doesn't filter down as a small.
barrie1 Avatar
barrie1 barrie
I don't have any I will check trabant welt
about 1 week and 5 hours later...
barrie1 Avatar
barrie1 barrie
is that red tube for the resuve tank?
A Spooky Ghost Avatar
A Spooky Ghost A Spooky Ghost
USA   USA
No, it acts like a higher bottom for the tank. So when the fuel goes below it- then you need the reserve..
Most 2 cycle mopeds, and older motorcycles have the same system. You could always leave it off, and be running on the full tank all the time. Which is fine, as long as you know how much fuel you have.....
Also, here is a link to some factory exploded drawings. http://www.trabant-original.de/otdbx/TDokumente_view.php
Yes your car did have head gaskets when new.
barrie1 Avatar
barrie1 barrie
I have put 2 head gaskets on her and cleaned fuel tank out car is running grate but now I have a new problem
the carb has a glass to see how much fuel is in it and it is not filling past the bottom mark so am I right in thinking to needle valve need's replacing or the float I have took the needle valve out and cleaned it thir was shit in it[ATTACH]5836[/ATTACH]
need.jpg    4.9 KB
USA   USA
Well, it could be the float is cracked{it isn't cork right?, I've never worked on the older trabis}, mis-adjusted, and or the needle valve is jammed / full of junk. Try putting the float in a cup of liquid (with a light weight on top) for a few hours. With it assembled, try to gently blow into the fuel inlet(hopefully with a clean hose!). When you flip the carb upside down, no air should pass.
If it lets air by, then she is worn out, or that valve is dirty & squirreled.. This applies to any carb ever made. grinning smiley
about 1 month and 2 weeks later...
barrie1 Avatar
barrie1 barrie
got a new needle valve car is driving grate on thing is it using a lot of fuel
1986 Trabant 601 Standard Universal
