Windshield washer pumps
Posted by jseabolt
Mar 13, 2017 09:00 AM
In reply to a post by Keri, post: 21307, member: 757
Correct, the intermittent function wiper switch does have a washer switch built in, however it switches the GROUND (B-) on and off at Terminal 53c, not the power. So, as a result, the (+) terminal on the pump must be supplied with power, tapped at the reverse light circuit.
Just pushing the wiper switch is much, much better than using any sort of push-button switch!
The wiper switch in mine has the intermittent function but does not have the washer logo on it. So I'm assuming there are several different types of these switches?
Mar 13, 2017 10:09 PM
In reply to a post by turbofiat124, post: 21310, member: 777
As the knobs are interchangeable, the marking on it is not a reliable indicator of the switch type.
You should check for the presence of Terminal 53c on the bottom edge of the switch. Some of the switches have a marked position, but no terminal.
Mar 14, 2017 03:11 PM
